turbulence modeling in turbofan
Old   November 9, 2010, 18:50
Default turbulence modeling in turbofan
Saima
Saima is an unknown quantity at this point
I am looking for documentation turbulence modeling in turbofa. If anybody has some papers or thesis on it please let me know.
Regards,
Saima is offline   Reply With Quote
Old   November 10, 2010, 05:01
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
hi
Can you elaborate more that what you want to know. whether you want to know about the best turbulence model for turbofan engine?
Regards
Far
Far is offline   Reply With Quote
Old   November 10, 2010, 08:19
siri is on a distinguished road
Salma
frankly, I don't know answer to your question but as soon as i read it I am somewhat curious for the way it sounded. i mean, does it being a turbofan engine signify something unique here?
as far as my knowledge goes, one picks appropriate turbulence model for an analysis based on its relative strength (or lack of it) in capturing the physics of interest at a particular region of geometry.
So practically speaking, it should not matter, whether you are analyzing for an aircraft engine or a valve in a heart. Its the physics of flow guiding the modeling choices most often rather than the application.
Please correct if I am wrong.
S
siri is offline   Reply With Quote
Old   November 11, 2010, 01:20
Hamid Zoka
Hamidzoka is on a distinguished road
Dear Salma
some turbulence models does not have a satisfactory performance in calculating turbulence characteristics of a specific flow such as lengh scale, etc.
So, you should refer to articles which are focused on evaluating turbulence models applied to turbomachines.
as far as i know, for turbomachinery applications k-Omega SST and h2f models show satisfactory results.
regards
Hamidzoka is offline   Reply With Quote
Old   November 21, 2010, 12:01
Saima
Hi all,
Thanks for your replies.
What i studied up-till now i derived RANS by using incompressible and x Navier stokes equations, read models from Zero,1eqiations... Reynlds stress Model and LES. I read pros and cons of every models. Frim literature anf fluent user gide its clear k-omega is googd for turbomachinery application.
But the topic which i have to write report was "Turbulence Modeling for Turbofan". We always take compressible flow for fan. Then i realized i should read turbulnec modeling with compressible effect. I found derivations upto RANS for compressible flow. But after that how can it implements on all of above models (Zero to LES).
I found k-omega model for compressible flow in Wilcox and fluent give k-epsilon as well (in fluent).
In most of the literature i found prople are using RANS and LES(conventional) for turbofan and having good results.
It's just confusion between compressible and incompressible. What could be my criteria. I have not found and compile report for turbulence model on turbofan. If any of you have please let me know.
Best Regards,
Saima
Old   November 21, 2010, 18:47
Administrator
jola's Avatar
Jonas Larsson
jola is on a distinguished road
Send a message via MSN to jola Send a message via Skype™ to jola
Turbulence modeling for mildly compressible flows is just a simple reformulation of non-compressible turbulence models. Only when you come up to hypersonic flows can it become necessary to model compressible effects on turbulence. You can get more information from the terms that can be neglected in mildly compressible flows if you read the governing equations chapter in my old thesis.
jola is online now   Reply With Quote
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 12:48
Turbulence modeling for fan/compressor blading Jonas Larsson FLUENT 1 April 13, 2005 15:08
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
