STL Surface Geometry Fixing
Old   October 28, 2010, 17:50
Default STL Surface Geometry Fixing
Brian Henry
EphemeralMemory is on a distinguished road
Hey, all, thanks for reading this.
I have a question about STL surface meshes. In particular, how to fix them.
Unfortunately, I work with biomedical applications, which apparently is notorious for having overly complex geometry, and as a result, geometry that is incredibly hard to fix.
First off, a clarification: what are overlapping elements exactly? I can isolate several in a mesh, and it seems to be a boundary condition on a boundary condition. Because of this, I cannot mesh it properly so that FLuent can run simulations.
I work with Mimics, and I am able to fix everything except overlapping elements, which render me unable to run simulations in Fluent. I was wondering, what tools are out there that don't cost thousands of dollars for licensing that I can use for STL repair? I tried fixing the overlapping elements manually, but I get lost when the image has multiple millions of elements and I narrow it down to about 20 overlapping elements.
EphemeralMemory is offline   Reply With Quote
Old   October 30, 2010, 20:05
Andy Jones
andyj is on a distinguished road
Hello
You might look at MeshLab. It can repair Stl files and many others. It is free open source.
http://meshlab.sourceforge.net/
andyj is offline   Reply With Quote
Old   October 31, 2010, 14:35
Brian Henry
Thanks, I have Meshlab, but I didn't know you can repair STL files actually...
I'll check it out.
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
user surface in post xinzhangabc CFX 0 February 24, 2005 07:29
Patran Volume Meshing Deb CFX 19 April 17, 2003 11:56
