Pressure correction on SIMPLE
Old   September 27, 2004, 21:45
Default Pressure correction on SIMPLE
Diego Nogueira
Greetings, For a simple wind pipe, using laminar incompressible NSE and SIMPLE scheme, I have problem I need some help with. The pressure correction step: P_old += P_new makes my pressure values TOO large over a short period of time, although for a simple pipe velocity converges, but not pressure. If I do P_old = P_new instead, pressure converges but mass conservation is compromised. Which one is the correct? Any idea about the nature of this problem I'm facing?
Thanks a lot!!
Old   September 28, 2004, 04:00
Default Re: Pressure correction on SIMPLE
Maciej Matyka
<table width="50%"> <tr><td> Did you try to overrelax (or underrelax) pressure correction term? I mean instead of using:
P_old += P_new
try:
P_old += alpha * P_new
where alpha is an over/underrelaxation factor (overrelaxation for alpha > 1). Some time ago I wrote a paper about SIMPLE where I used overrelaxation factors to speed up covergence - see my page and search for "Driven Cavity" paper. </td></tr> <tr><td> Maciej Matyka<A HREF="http://panoramix.ift.uni.wroc.pl/~maq/eng/">http://panoramix.ift.uni.wroc.pl/~maq/eng/</a> </td></tr> </table>
Old   September 28, 2004, 21:48
Yticitrov
Hey,
SIMPLE worked with over-relaxation for you?
Regs
Y
Old   September 29, 2004, 04:09
Maciej Matyka
Nope, just wanted to point out that not only underrelaxation exists. Did not try to run SIMPLE with overrelaxation.
Best, M.
Old   September 29, 2004, 10:02
Diego Nogueira
Thanks Matyka. Actually I have your simulations CD and it was usefull, although I don't understand why I'm facing this problem. I'll try to better explain the situation.
I modelled a 3D wind pipe, initial dimensionless velocity 1 on inlet area, 0 anywhere else. Pressure is 0 everywhere at iteration 0. When I start iterating, since the velocity difference is large, a large pressure difference occurs, trying to push the air towards the other end of the pipe. The problem is, at some point the pressure difference stops being that large, but since I use P_new += alpha*P_old for pressure correction the pressure values start acumulating and at some point in time I have HUGE pressure values and then the simulator starts having problems ...
Using this approach, the pipe converges perfectly, but when I use a more complex environment, such as a pipe full of obstacles, it would take longer to converge, but pressure explodes before convergence.
Did I make my point now?
Thanks for the help, guys.
Old   September 29, 2004, 21:08
Halim Choi
After correcting the velocity components, update pressure as follows;
C --- CORRECT PRESSURE AT CELL-CENTER
PPREF=PP(IPREF,JPREF)
IF(IPRESS.EQ.1) PPREF=0.
DO I=2,NIM
DO J=2,NJM
P(I,J)=P(I,J)+RELAX(1)*(PP(I,J)-PPREF)*KBLK(I,J)
PP(I,J)=0.
END DO
END DO
PREF=P(IPREF,JPREF)
IF(IPRESS.EQ.1) PREF=0.
DO I=1,NI
DO J=1,NJ
P(I,J)=P(I,J)-PREF
END DO
END DO
Here IPREF, JPREF is a reference point, usuallly IPREF=2, JPREF=2.
IPRESS=1 means there is a pressure bounary condition in the solution domain. IPRESS=0 if there is no pressure boundary condition in the solutiopn domain.
KBLK(I,J)=1 for fluid and 0 for solid.
RELAX(1) is the under-relaxation factor for pressure correction.( for SMPLE, RELAX(1)=0.7, for SIMPLEC, RELAX(1)=1.) Keep in mind updating PP(I,J)=0 at every iteration level.
NIM=NI-1, NJM=NJ-1
Halim CHoi
Old   October 10, 2004, 15:43
Diego Nogueira
The idea is, in the beginning the pressure difference is large so I get large pressure values. After some time, the difference gets smaller but since:
it keeps on accumulating and the large values from the beginning remain since I won't get any negative pressure values. Could it be my initial conditions?
I start with pressure=0 everywhere and fix it to zero in the outflow cells. I expected to get a larger pressure value close to the inlet and it would decrease to zero the closer it gets to the outflow area, but that's not what's happenning.
I appreciate the attention.
Divergence detected in AMG solver: pressure correction emlejeen FLUENT 5 December 15, 2016 00:47
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
Simple question about pressure variation Rooz Main CFD Forum 3 February 6, 2004 17:24
pressure driven flow by pressure correction method justentered Main CFD Forum 0 December 30, 2003 00:52
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
