domain decomposition
Old   October 22, 2010, 13:24
Default domain decomposition
dshawul is on a distinguished road
I am trying to implement a non-overlaping domain decomposition solution using a dirchlet-neumman algorithm for exchanging information at ghost cells.
The velocity prediction is solved correctly but I have a problem with the pressure solution. When I try to solve the cavity flow split in to two domains at the middle,
I get very big values for the left and right domain due to the all round Neumann boundary condition for one of the domains. Since it is incompressible solver,
only relative pressures are important. The way I did it before is to finish the solution with whatever values the solver comes up,
then decrement the value of the reference pressure during post processing. How to handle this in DD I don't know.
Also it seems to work with an SOR solver which gives value of p close to 0 (the initial guess). CG solver fails with big values in the first iterations.
I would like to avoid solving a coarse problem to coordinate solutions between different solvers, which is the reason why I am trying to use dirichlet-neumman algorithm (If I understood correctly).
I am new to this field and any hints or explanations of the algorithms are very welcome.
thanks in advance
dshawul is offline   Reply With Quote
Domain decomposition method Bram OpenFOAM 5 November 28, 2017 05:42
Mesh generation software for Domain Decomposition ali987 Main CFD Forum 0 November 10, 2009 12:06
CFX - domain decomposition. Urgent!!!! Elena Saldaeva CFX 4 June 30, 2008 08:18
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
Domain decomposition rajesh Main CFD Forum 2 August 31, 1999 05:22
