Hydraulic diameter vs radius
Old   September 22, 2004, 11:39
Default Hydraulic diameter vs radius
Christian
Hi.
Does anyone know why there are a factor 4 in difference between the hydraulic diameter (d_H) and the hydraulic radius (r_H) ?
d_H will reduce to d for a round tube and that is logical. r_H will reduce to r/2 for a round tube. But where is the logic in that?
Does anyone know why ? What is the story behind this difference?
Old   September 22, 2004, 23:03
Default Re: Hydraulic diameter vs radius
Angen
I noticed this difference and realized that hydraulic diameter is mainly used in close conduits (pipes, annulus, etc.) whereas hydraulic radius is mainly used in open channel flows. In case of pipe considered as an open channel only half of the pipe perimeter enters into the definition of hydraulic radius. This is only my guess.
Angen
Old   September 23, 2004, 04:10
Christian
Hi.
Well yes, you are correct. But when a open channel is considered as in your example, also only half the areal is entered into the definition.
Old   September 23, 2004, 11:40
Angen
Yes you are right. It still would be r/2. So, why it is so? Anyone else guess?
Angen
Old   September 23, 2004, 15:06
ag
Refer to Fluid Mechanics, by F.M. White, pp. 341-342.
Old   October 8, 2004, 23:03
Noora
I think its a matter of definition. There is nothing to embaded physical. The hydraulic dia is defined as 4A/P, whereas the other one as A/P. The factor of 4 comes from the definition A=pi (r^2)/4, area of circle.
Adam
Old   November 17, 2004, 09:42
Default hydraullic dia.
abhishek
sir how to calculate hydraullic dia of the inclined plates in which water is flowing between them Also how to calculate hydraullic diameter in journal bearing in its rotating conditions in which it have some eccentricity. both journal bearing and plates have zero length in direction normal to the paper.
Old   November 24, 2004, 04:23
Default Re: hydraullic dia.
queram
If you need for Re number determination, I`d put there the distance between the plates. As of the bearings, there`re many papers dealing with the modelling of the oil film behaviour; a time ago I bump into some when helping to a friend of mine.
Old   August 5, 2009, 19:10
Default Hydraulic diameter and hydraulic radius
Diana
Jenny is on a distinguished road
Any idea about hydraulic diameter and hydraulic radius relationship? is Dh=2Rh?
Jenny is offline   Reply With Quote
Hydraulic Diameter - Series of Holes Jop FLUENT 6 January 14, 2019 10:41
equivalent diameter vs hydraulic diameter swamysrikanth Main CFD Forum 1 April 5, 2010 10:01
[GAMBIT] hydraulic diameter? Zweeper ANSYS Meshing & Geometry 6 January 4, 2010 01:44
hydraulic diameter in 2d ahsan FLUENT 2 August 28, 2009 16:22
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 11:58
