Input leaks. 20 free element edges found.HELP Meshing Hypermesh
Old   October 18, 2010, 11:33
Exclamation Input leaks. 20 free element edges found.HELP Meshing Hypermesh
Pankaj
panky is on a distinguished road
Iam trying to mesh a heat exchanger pipe with inside cylinder dia9.5mm , length 1200mm and outside cylinder dia 28.5mm and length 1300mm. 2d mesh is fine but while using 3d tetra mesh with cfd mesh its giving the above mentioned problem. The parameters for cfd mesh im using are
Total BL thckness-3mm
First layer thckness-.5mm
growth rate-1.
Kindly suggest.
panky is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
is free meshing or mapped meshing is best for flow problems shanu Main CFD Forum 0 February 18, 2010 12:58
[Other] is free meshing or mapped meshing is best for flow problems shanu OpenFOAM Meshing & Mesh Conversion 0 February 18, 2010 12:56
Meshing Ring Element Jalen ANSYS Meshing & Geometry 2 October 20, 2009 10:21
