drop deformation in 2D
Old   September 17, 2004, 06:07
Default drop deformation in 2D
Junseok Kim
Is there any reference for the taylor deformation D=(L-B)/(L+B)=(?)Ca for the 2 dimensional space with shear flow.
Thanks
Old   September 19, 2004, 20:36
Default Re: drop deformation in 2D
Pete
In literature, it seems that only some 3D formulae are there. Anyway, you may find some helpful information in the following two review papers:
1. Rallison, J. M. 1984 The deformation of small viscous drops and bubbles in shear flows. Annu.Rev. Fluid Mech. 16, 45–66.
2. Stone, H. A. 1994 Dynamics of drop deformation and breakup in viscous fluids. Annu. Rev. Fluid Mech. 26, 65–102.
Good luck
Old   September 19, 2004, 20:42
Junseok Kim
That's what I wondered, so far I only found 3D results. There are a couple of 2D simulations, but no theoretical result, partly due to physical experiments are mostly 3D. But I think it is better to have 2D theoretical results to compare numerical code test because most cases, people start coding 2D and then extend it to 3D.
Thanks for the references.
Junseok
Old   September 27, 2004, 19:17
xueying xie
I'm also doing 2D drop deformation to prepare for 3D simulation. If you find any theoretical results for 2-D drop, please let me know, because I also want to compare my results with the analytical one. Thanks in advance.
Old   October 19, 2004, 22:56
nizar
Hi Pete,
Actually, I am looking for these two references. I would really appreciate if you can send them to me.
Regards
Nizar
How to plot pressure drop with Periodic BC? bigfans FLUENT 7 November 8, 2016 12:28
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 05:23
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 15:50
Drop deformation Ron FLUENT 2 June 24, 2004 07:05
Unsteady drop deformation under zero gravity Ron FLUENT 1 June 11, 2004 11:02
