TVD scheme in unstructured finite volume discretization |
abcdef123
Rep Power: 16 ![]() |
I am trying to extend the TVD scheme to an unstructured finite volume discretization. The problem is determining r for this scheme in the unstructured mesh domain, which is defined as the local ratio of upstream gradient to downstream gradient (from Coputational Fluid Dynamics: The FVM by Versteeg and Malalasekera). Any help with this would be greatly appreciated. Thanks in advance. |
ganesh
Rep Power: 17 ![]() |
Dear abcdef,
Although not directly relevant to your question, please take a look at Jasak's paper on developing higher order NVD schemes for unstructured meshes. These are related to TVD, and the paper talks about developing Gamma scheme, which wroks fine for a range of problems on arbitrary polgonal meshes. You can google the paper, I don't recall the exact title. Regards, Ganesh |
Dokeun, Hwang
Now I'm reading 'TVD schemes for unstructred grids', M.S.Darwish, Int. J of Heat and mass transfer, 2003, 599-611
I just leave this message for someone else... |
Finite Difference Vs. Finite Volume | elankov | Main CFD Forum | 43 | December 18, 2010 16:30 |
formulation of finite element&finite volume method | ravindra | FLUENT | 0 | June 27, 2007 12:04 |
Finite Volume Approach For Unstructured grid | APURVA SHUKLA | Main CFD Forum | 2 | March 15, 2001 00:14 |
Unstructured Finite Volume Method | Marcio Aredes Martins | Main CFD Forum | 4 | January 7, 2000 20:23 |
Data Structure for the unstructured finite volume method | Anthony | Main CFD Forum | 4 | February 2, 1999 19:24 |
