Help !!! : Computation/Calculation of Heat flow through several layers of Glazing
Old   October 3, 2010, 19:06
Lightbulb Help !!! : Computation/Calculation of Heat flow through several layers of Glazing
glazing is on a distinguished road
Dear friends,
I want to compute the heat flow through several layers of glazing.I have incorporated a heat sink(with a coolant flow tube) in one of the intermediate layers which will remove the heat incident on the glazing.
A layer of translucent insulation is also present to prevent heat from transmitting to the inside.
I do not have any knowledge of CFD and will be gratefull to all those who can help me arrive at a solution (by calculation..preffered or computation).
1. i need to know the heat that needs to be removed by the heat sink to prevent any heat from the outside being reflected to the outside.
2. the rate of flow of the coolant to enable the above.
3. the preffered medium in contact with the heat sink ( located on the periphery of the glass window) to enable maximum heat capture that can be passed on to the heat sink.
Thank You .
glazing is offline   Reply With Quote
Old   October 5, 2010, 10:27
otd
private
otd is on a distinguished road
Could you post a sketch?
otd is offline   Reply With Quote
Old   October 10, 2010, 09:44
Lightbulb Sketch
I have attached the sketch.I look forward to your reply.Thank You.
Old   October 10, 2010, 17:48
otd
private
I don't think you have a CFD problem. The fluids problems (flow of liquid in a tube, natural convection on a cooled surface) are text book and have been reduced to correlations to yield convection coefficients on the inside surface of the tube and the outside (left) surface of the glazing.
It appears that the rest is a multi-layered conduction and radiation problem. You need to consider conduction from the ambient fluid on the left into and through your structure and top-to-bottom conduction in your structure, so you have a two-dimensional (or 3?) conduction problem.
The radiation transport can be pretty tricky, but (I think) all the parts are covered in graduate level transport texts.
Maybe some other readers can add to this - or suggest a heat transfer web site for further help.
otd
Old   October 12, 2010, 07:27
Lightbulb
Can anyone help me? I do not have any knowledge of heat transfer.I am also looking for your recommendation of a liquid/gas which is transparent and at the same time can capture the heat from the radiation and pass it to the heat sink.
Old   October 12, 2010, 07:28
Thank you.
heat conduction in solid and convection in flow kunal FLUENT 3 February 29, 2012 05:42
Heat source function of mass flow MarcVi Fluent UDF and Scheme Programming 0 September 16, 2010 14:16
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
axial flow around a cylinder -heat transfer model? Ralf Schmidt FLUENT 0 March 21, 2006 04:29
Airpak: Problems with heat flow contour conditions Ivan de Miguel Urain FLUENT 1 November 16, 2001 10:36
