May 8, 1999, 14:14 |
Pressure BCs in FLUENT
Do you know, in FLUENT5, if when you put a pressure as inlet this implies that the inlet velocity is equal to zero? in other term, is it a total pressure or a static pressure? thanks julien
May 11, 1999, 05:30 |
Re: Pressure BCs in FLUENT
Hello Julien,
If you use Pressure inlet it is the total pressure of the fluid at the inlet plane, In incompressible flow the static pressure are related with the total via the bernuolli relation. In compressible flows the static pressure are related via isentropic relation for an ideal gas. You enter the gauge total pressure (p_abs=p_operating+p_gauge), see operating panel. Bye |
May 13, 1999, 20:16 |
Dear client,
For details, please refer to the User's Guide. But to give you a quick answer, it's total pressure if the flow enters through the inlet. Come to think of it, the GUI actually shows that FLUENT 5 expects a total pressure at the inlet. |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
How to give pressure inlet in Fluent | Vijayaragavan | Main CFD Forum | 1 | December 17, 2007 09:40 |
pressure outlet BC for Boussinesq with Fluent | stephane | Main CFD Forum | 1 | October 20, 2007 07:09 |
Definition of pressure | Ola Nordblom | FLUENT | 1 | August 16, 2001 15:58 |
