Lagrangian Approach
Old   August 23, 2004, 14:47
Default Lagrangian Approach
Biswajit Sarkar
What is the basic difference between Lagrangian approach and Eulerian approach?
Old   August 23, 2004, 15:51
Default Re: Lagrangian Approach
Khurram
Lagrangian approach is mainly used in solid mechanics, where the grid points "sits" on the material and the grid points move with the material. Eulerian approach is mainly used in fluid mechanics where the grid points are fixed in space and the fluid is moving accross them.
Old   August 24, 2004, 01:42
Biswajit Sarkar
Dear Sir, A Very hearty thanks to you. I would like to ask you another question How lagrangian approach is useful in CFD?
With regards, Biswajit Sarkar
Old   August 24, 2004, 03:02
Junseok Kim
In the multi-phase fluid dynamics, Lagrangian approach (immersed boundary method, front tracking method) tracks the interface explicitly. On the other hand Eulerian method (level set method) captures the interface with implicitly defined level set function on the Cartesian coordinates.
Old   August 25, 2004, 17:48
Khurram
Hi
As Kim mentioned, in Fluid structure interaction problems, we have to employ moving mesh for the fluid. One of the way to handel this problem is Arbitrary Lagrangial-Eulerian formulations. (Though the word arbitrary is misleading!) In ALE formulation the mesh velocity comes into the convection term of the fluid problem. For solid part we still use lagrangian approach.
I hope this answers your question!. Dont hesitate to ask again!
Old   August 26, 2004, 07:32
Biswajit Sarkar
Dear Sir, I am totally new in this field. Now i am trying to develop my basic concepts. How could I build concepts. I am basically a Chemical Engineer.
Old   August 29, 2004, 17:04
Khurram
It depends what you are doing and what are your plans for future. Assuming you have some applied project, then I would say get some CFD book and develop some 2D programs. If you have passed that stage and you are comfortable with CFD and looking to go into multiphysics problems then you have to follow some classical papers, which can give you implementational details.
Old   August 31, 2004, 02:18
Biswajit Sarkar
Dear Sir, I have done M.Tech in Chemical Ebgineering with specilization Computer Aided Process Plant Design from IIT Roorkee. Presently I am a lecturer at Jaypee Institute of Engineering and Technology. My M.Tech dissertation was Modelling of Spray Dryer. Now I am interested to persue my Doctoral Thesis in in the field of experimental and computational analysis of gas-solid flows. What should I have to do?
Old   May 4, 2012, 09:01
Default Dear Biswajit
Saurabh
saurabhk is on a distinguished road
Hey Biswajit, this is Saurabh. You said that you M.Tech topic was modeling of spray drying process. So have you done CFD modeling. If yes which software have you used. Please tell me as currently I am working on modeling of spray drying process.
saurabhk is offline   Reply With Quote
Old   January 25, 2013, 09:31
Default Spray dryer modelling
Alime Cengiz
cngz is on a distinguished road
Hi, it's Alime. I am also working on spray dryer modelling. I have read and searched several tutorials, but the model that I made didn't work the way I want!. Could you please suggest me some documents which are about spray dryer modelling? I really appreciate any kind of your help.. Thanks in advance.
cngz is offline   Reply With Quote
Euler-Euler vs. Lagrangian particle tracking for biomass pyrolysis in a rotary kiln audrey Main CFD Forum 0 February 22, 2011 13:09
lagrangian vs eulerian approach leopoldo luongo CFX 1 June 19, 2006 11:12
tutorials of lagrangian approach Luca Stabile FLUENT 0 January 21, 2006 08:20
Lagrangian Approach Biswajit Sarkar Main CFD Forum 3 August 4, 2005 14:42
Statistical Approach for Lagrangian Two Phase Model Hesham El-Batsh Main CFD Forum 0 November 20, 1998 10:20
