Fluid dynamics
Old   September 1, 2010, 02:45
Default Fluid dynamics
Sharada
sharada77 is on a distinguished road
Pardon me if this questions sounds silly....i am a novice to Fluid dynamics..
I want to know how the free stream velocity of a fluid varies along a curved surface(It decreases or increases)...How the boundary layer development affects this free stream velocity.
I also want to know how the drag force affects the heat transfer co-efficient.
sharada77 is offline   Reply With Quote
Old   September 1, 2010, 21:36
Naveen
vetnav is on a distinguished road
Hello Sharada,
The question is too general to answer, usually if x is the stream wise direction in laminar boundary layer theory we assume external flow varies as ~ x^m where the variable 'm' take different values.
Lets assume the flow is laminar as you move downstream from the nose of the object as the thickness of the boundary layer grows the free stream velocity should increase in order to satisfy the mass conservation.
A perfect reference to answer your question is the book "Laminar boundary layers" by L. Rosenhead, for basics you can refer the famous book "Boundary layer theory" by H. Schlichting.
Hope this information is helpful
Best
Naveen
vetnav is offline   Reply With Quote
Old   September 2, 2010, 06:11
Default hello
Sharada
Thank you Naveen
Old   September 3, 2010, 09:13
Default hello
Sharada
Can anyone please explain me why in laminar fluid flow surface roughness is neglected but taken into account only in turbulent flows...
Old   September 3, 2010, 13:34
Default laminar vs turbulent
Naveen
Surface roughness results in small disturbances in the flow, when the flow is laminar (Reynolds number is small) these disturbances are killed immediately by the viscous effects, but when the flow is turbulent (Reynolds number large) any small disturbance will grow and will effect the flow behavior.
You can think this in terms of relative importance of inertial and viscous forces also.
As you said you are not familiar with fluid mechanics I will put it simply
Laminar flow ---> small disturbances gets killed.
Turbulent flow ---> infinitesimally small disturbances also grow and affect the flow.
Hope I did not confuse you more.
Old   September 6, 2010, 09:18
Default hello
Sharada
thankyou so much .........
Old   September 16, 2010, 06:15
Default Mesh quality check
Sharada
I am learning meshing(both structured and unstructred) on Ansys icem cfd tool...i want to know what are different variables we have to check for performing quality check in unstruvtred meshes and structured meshes.
I also want to know if aspect ratio, and skewness is important to check in unstructred meshes..if yes why it is important and what is the optimum value.
Please suggest what changes should be made in meshing to get the optimum values.
Grid-Based Fluid Dynamics Geometrian Main CFD Forum 0 October 17, 2009 07:58
Fluid Dynamics Eng - PAX Mixer - San Rafael, CA Gary Jong FLUENT 0 February 25, 2008 21:46
PhD Positions Available Nano and MicroSystem Fluid Dynamics using OpenFOAM lynne OpenFOAM 0 March 8, 2006 10:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Fluid Dynamics Rajiv Kumar Main CFD Forum 5 July 21, 1999 21:46
