Grid Clustering
Old   August 14, 2004, 07:20
Default Grid Clustering
Arul Prakash K
Dear all,
We are working in Grid generation of complex geometries. we generated many complex grids. In addition we can able to do clustering (grid adaptation) along the middle portion in both axial and radial directions. But we are struggling to cluster along the boundary where we want to capture the sharp gradients.
If anyone knows kindly reply..
Thanks in Advance,
Yours sincerely,
Arul Prakash K
Old   August 14, 2004, 14:28
Default Re: Grid Clustering
Doctor Blade
What type of grid generation are you using?.
Old   August 14, 2004, 14:40
Arul Prakash K
We are generating Structured Grid generation using Multi Block Technique
Old   August 14, 2004, 16:17
Arul Prakash K
We are using Structured grid generation technique. The outer boundary was created using algebraic method and finally smoothed using elliptic grid generation technique.
Suggestions regarding clustering along the boundaries are most welcomed.
Old   August 15, 2004, 16:11
Doctor Blade
If you are using elliptic grid generation, there are the "forcing functions". I will assume that you know these functions, but you can read about it in many texts. If your answer is: hey! I know the forcing functions P and Q yet, but they only clusters over radial coordinates!. Then I don't know the answer. I am nowadays traying to cluster the iso-eta lines (circumferential lines) over the boundary, but the forcing function requires a iso-xi line of reference to cluster around too.
Old   August 16, 2004, 02:29
Arul Prakash K
Dear Doctor Blade,
Thank you very much for your response. I adopted P and Q functions. I am using both iso-eta and iso-zhi lines. But still I am facing problem to cluster near the boundaries. Whether U manage to cluster near the boundary??
Thanks, Arul.
Old   August 16, 2004, 07:18
Doctor Blade
Well, if you are using P and Q functions, I congratulate you if your iteration converges to a solution. I've not been capable of it in my trials. But I can remember P or Q functions have a iso-eta line of clustering reference inside the exponential factor, haven't they?. What happens if you fix this iso-eta line of reference to be the boundary one?.
And another question: are you using Matlab?
grid clustering using elliptic equation khairy Main CFD Forum 0 March 5, 2005 22:00
uniform grid and beta clustering rvndr Main CFD Forum 0 February 22, 2004 00:19
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 09:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 17:43
