MESH Generation
Old   August 12, 2004, 09:35
Default MESH Generation
Dan
Does anybody know what the best reference is for multi-block structured mesh generation in the CIRCULAR plane? I am particularly looking for a standard 5-block grid generation in a circle (i.e, a central block surrounded by 4 other same-size blocks).
The reference could be a book, a TM, or even better, a simple Matlab or Fortran code? Any of these would work for me.
Thank you.
Old   August 15, 2004, 11:09
Default Re: MESH Generation
Rami
Dan,
It seems simple enough to write the code by yourself.
In the lack of details, I assume you need to mesh an inner circle (0 < r < Ri, 0 < phi < 2*pi) and four indentical annular blocks (all with Ri < r < Ro, the first with 0 < phi < pi/2, etc) and uniform grids in r and phi. I also assume the grids are matched on the block interfaces.
It would be trivial to write a code that generates each of the blocks vertices in polar coordinates (and transform to Cartesian if needed). As the blocks are structured, cell indices determine the vertices indices. All you need to play with is the values Ri, Ro and the number of intervals in r and phi, and write the grid in the desired format.
If any of the above assumptions should be relaxed, the changes to the code should be minor and straightforward.
I hope this helps.
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
mesh generation for in-cylinder fluent simulation hennas ANSYS Meshing & Geometry 2 May 31, 2011 16:08
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 14:47
