Turb. modeling
Old   August 11, 2004, 05:46
Default Turb. modeling
Keanu
I am fairly new in CFD. I wrote 2D cell-centered finite volume NS solver employing Roe FDS and Baldwin-Lomax model. However, I have covergence problems. Some research engineers compute eddy viscosity in every 5-6 iterations. Do you think it works well for better convergence? Thanks in advance...
Keanu.
Old   August 19, 2004, 08:00
Default Re: Turb. modeling
Jonas Bredberg
Hi there,
I believe that a better way to smooth-out convergence problems is to include relaxation, rather than skip to compute the eddy-viscosity. Thus, compute the eddy-viscosity each iteration however update it as: mu_t_new=alpha*mu_t_new+(1-alpha)*mu_t_old This scheme can be applied to a number of variables. Another way to test is to compute a simple non-turbulent flow, and exclude the Baldin-Lomax model. There might be some problems with the momentum equation rather than the turbulence equation,
Cheers Jonas
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 12:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 15:49
Solid Modeling Chris Main CFD Forum 10 July 2, 2002 08:12
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 10:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 20:08
