finite-volume poisson solver
Old   August 14, 2010, 21:05
Default finite-volume poisson solver
Scott
Scott2 is on a distinguished road
Can anyone direct me to code or literature for a 3D finite-volume Poisson solver on non-uniform Cartesian coordinates? I am more concerned with the proper determination of the coefficient matrix than the solution method for the system of equations. Any help is greatly appreciated.
Thanks,
Scott
Scott2 is offline   Reply With Quote
Old   August 16, 2010, 21:21
Default References
Wu Jian
harbinyg is on a distinguished road
Send a message via MSN to harbinyg
I remember there are two pieces of old paper which maybe help you,
one is : Physica D (1992) High order finite volume approximations of differential operators on nonuniform grids
another one is : Journal of Computational Physics, 1980, Solution of poisson equations on a nonuniform grid
harbinyg is offline   Reply With Quote
Old   August 16, 2010, 23:05
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Thanks,
Scott
Have a look at fishpack by Paul.
solution matrix is determined in that by finite difference method.
arjun is offline   Reply With Quote
Old   August 20, 2010, 04:16
Hans Bihs
valgrinda is on a distinguished road
Hei Scott,
you could use the code from the Peric book ( ftp://ftp.springer.de/pub/technik/peric/ ) . Or you could use the NaSt3DGP code, which is finite-difference, time explicit and projection method (http://wissrech.iam.uni-bonn.de/rese...3DGP/index.htm).
By the way, if you use a cartesian domain, you can also easily use finite differences.
Regards
Hans
valgrinda is offline   Reply With Quote
finite volume, poisson solver
Finite Difference Vs. Finite Volume elankov Main CFD Forum 43 December 18, 2010 17:30
sliding mesh with Finite elements or finite volume tool Main CFD Forum 0 October 9, 2008 11:07
Equations for finite difference, element & volume W.L.C. Main CFD Forum 9 April 3, 2001 13:08
Finite Volume midplane algorithms Ricardo Bonon Main CFD Forum 0 May 17, 2000 18:03
finite volume method for CFD analysis of 2D blunt body Aditya Vaze Main CFD Forum 1 January 19, 2000 14:55
