How Accurate is the Tait Equation of State?
Old   August 4, 2004, 01:32
Default How Accurate is the Tait Equation of State?
Cary Kenny
So far Tait EOS is a standard EOS applied to water, particularly in the highly pressurised regime. The question is, how accurate is the Tait EOS when it is used to modelled region where the water pressure is negative (under tension)?
Old   August 4, 2004, 12:59
Default Re: How Accurate is the Tait Equation of State?
Angen
I think this equation has a simple mathematical form. Can you write it down for us?
Andy
Old   August 4, 2004, 13:20
George
I'm not sure what do you mean by a "negative pressure", as strictly speaking there is no such thing in a fluid. Generally, if the (absolute) pressure decreases sufficiently, then you get phase change, i.e. cavitation. I think you need to better specify your problem.
Regards, George
Old   August 4, 2004, 14:01
jasond
Water (and other liquids) can support some tension, or absolute pressures less than the vapor pressure, without phase change. The tensile strength is generally very small and depends on many factors. I could be mistaken, but I believe that the original poster is referring to pressure relative to the vapor pressure.
Old   August 4, 2004, 23:48
Cary Kenny
Thanks guys, your views are greatly appreciated. To redefine my earlier question, this is the scenario:
Water, similar to solid, posses a tensile strength, i.e. ability to withstand distortion. For solid, e.g. if a metal bar is pulled from both end, the bar will resist to be pulled apart (here tension refers to negative direction of force, as compression refers to positive one). So is water, if a "bar of water" is pulled, it will resist to break, but due to cavitation nuclei, it is very common to see the water bar "break" easily - and produce cavitation. The tension produced by the decrease in total pressure is the reason, as Jasond said.
In numerical simulations, Tait EOS is commonly used to represent "pure" water i.e. no cavitation exist in water, paticularly in the case of high pressure regime (<10GPa). But is Tait EOS still valid if inside the water there exist some pressure region of -10MPa?
Thanks
Old   November 20, 2010, 03:23
Default How to Define Tait's Equation of State for water in Fluent
Bhaskar K
bhaskarsharma is on a distinguished road
How to replace the constant density value for water by Tait's Equation of state in fluent
Last edited by bhaskarsharma; November 21, 2010 at 11:01. Reason: to be more precise
bhaskarsharma is offline   Reply With Quote
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
How can I add an equation of state for rho and cp ?? Canesin OpenFOAM Programming & Development 0 May 14, 2010 18:52
Equation of state stvtiegh OpenFOAM Running, Solving & CFD 3 September 12, 2008 07:24
Real Gas Equation of State Used in Combustion? Jake Cannon Siemens 0 January 16, 2007 18:13
Roe scheme for general equation of state zouchu Main CFD Forum 3 August 10, 2000 17:46
