RUBBER EXTRUSION SIMULATION
Old   July 29, 2004, 07:48
Default RUBBER EXTRUSION SIMULATION
RICAROD OTERO
Hello everbody, i am looking for any software for rubber extrusion process simulation.
I will be very pleauser if you can give any informaticon.
Thank you.
Old   July 29, 2004, 13:13
Default Re: RUBBER EXTRUSION SIMULATION
matej
hi,
where do you want your rubber to extrude from? )
does the material flow in some rigid geometry, so youcan treat it as a fluid?
is it newtonian fluid?
or is it more like bumping elastig jelly?
is any chemistry involved?
matej
Old   July 30, 2004, 04:04
RICAROD OTERO
It is the normal process of Extrusion in wich you put the ruber in a screew and it gets hotter but below melting point. Then the rubber goes thru the DIE with the required geometri. Normaly due to the expansion of the rubber, you need to change the Die geometry to get the right final profile.
What i need is a software to predict the final profile of the extruded rubber in order to correct the die.
Thank you.
Old   July 30, 2004, 04:49
HVN
Perhaps polyflow
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 04:36
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
Extrusion Simulation Lord Kelvin Main CFD Forum 0 January 31, 2011 06:36
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 09:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 19:57
