Question on boundary conditions
Old   July 27, 2004, 20:36
Default Question on boundary conditions
Diego Nogueira
I'm using SIMPLE method and have a doubt on physical BC's.
For pressure, on has to make the gradient normal to the wall equal zero, but how to calculate the pressure of the fluid cell close to it?
In order to calculate the pressure of a cell (I'm using poisson) I'm supposed to use the values of pressure around the cell. Does it include boundary cells?
The problem is that I'm reaching very high pressure values close to the walls.
Old   July 27, 2004, 22:26
Default Re: Question on boundary conditions
centaur_ks
refer to 'Numerical methods for Fluid flow and heat transfer' by Suhas V Patankar. The book explains the answer in great details...
Old   July 28, 2004, 16:26
Diego Nogueira
I'll look for that one. Thank you.
Old   July 29, 2004, 13:17
agg
1) To calculate the pressure values near the boundaries you should include the unknown boundary cells.
2) To treat boundary, you can have a look at the way it is done in FISHPACK which is an elliptic equation solver. http://www.scd.ucar.edu/css/software...ck/technote.ps
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 06:35
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
question about implementing boundary conditions saygin Main CFD Forum 0 July 6, 2006 08:08
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
