backward facing step problem
Old   May 4, 1999, 17:32
Default backward facing step problem
Yung-Ming Chen
Hi, there,
I am trying to test a CFD code. One of the example I plan to test is the problem of "2D backward facing step" problem, i.e., a flow pass through a duct, at downstream the duct has a step down. Could any of you direct me to dig out some literature about the nature of this example? e.g., any analytical or approximation solution for this example, numerical difficulties perople are facing ... etc.. The following is a schematic picture of the duct. The flow is flowing from the left to the right. Any help is appreciate it.
|____________
Yung
Old   May 5, 1999, 01:17
Default Re: backward facing step problem
Tareq Al-shaalan
I know there are lots of work has been don on backward step. So you should not find a problem to find it in the literature
Old   May 5, 1999, 10:25
John C. Chien
It is one of the standard test case in CFD to test the numerical algorithm and turbulence modeling. It cas be either laminar or turbulent. You need to know the flow separation bubble size in order to make the computational domain large enough to cover the downstream duct and part of the upstream duct. The separation bubble size for turbulent flow is about six step heights. It is a function of Reynolds number for laminar flow.
Old   May 11, 1999, 23:04
Budi Dwisakti
Yung,
You may start with this
Speziale, C.G.; Thangam, S. Analysis of an RNG based turbulence modeling for separated flows. Int. Journal of Eng. Sci. 1992
OR
Turbulence Modeling for CFD by Wilcox
Hope this help
Budi
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
air-fuel mixing in backward facing step abdullahkarimi Main CFD Forum 0 March 19, 2011 19:39
Backward Facing Step on buoyantSimpleFoam tetsuro86 OpenFOAM Running, Solving & CFD 0 June 9, 2010 18:10
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
backward facing step ryoga Main CFD Forum 1 March 9, 2003 03:52
