boussinesq model problems help needed
Old   July 15, 2004, 04:13
Default boussinesq model problems help needed
nabeel mohsin
hi, i am using natural convection in simulating quenching of hot cylinder in oil.i have four question. 1.how you determine value of g in operating condition and what its effect. 2.when you use this model how density in material properties is determined or simply density is given at that temperaure in data tables. 3.what will be operating temerature if fluid is at 313 and cylinder wall will be at 1473K. 4.for transient you use first steady and then unsteady.Can i use coupled in steady and segregate in transient.how can i determine which solver i should use. nabeel
Old   July 29, 2004, 20:10
Default Re: boussinesq model problems help needed
jenn
In the Boussinesq model, the fluid density is assumed to be the same except it appears in the N-S equation with the graviation g as a bouyancy term. So the oil density inside the cylinder will not change. Maybe you should not use the Boussinesq model?
non-linear k-epsilon model implementation problems Saidi Main CFD Forum 2 March 4, 2010 14:23
Help needed in 3D multiphase micro model ehsanfareed FLOW-3D 1 November 29, 2009 20:07
Help needed regarding Dynamic Mesh Model Saad FLUENT 4 April 9, 2005 03:09
Problems with the same model Ricky Siemens 0 August 3, 2004 10:22
Any other model instead of boussinesq model? moon FLUENT 1 September 26, 2003 06:45
