Neumann boundary condition question
Old   July 13, 2010, 08:25
Default Neumann boundary condition question
lost.identity is on a distinguished road
I'm trying solve a simple diffusion problem in spherical coordinates. One of the boundary conditions I use of Neumann type where I specify that the temperature gradient at the inlet is zero.
The way I'm trying to implement it in my code as as follows
T (at node 1) = T at (node 2).
But since the solution progresses from node 1 to node 2 and so on, does this mean that I have to use the temperature of node 2 at the previous timestep?
If on the other hand the Neumann boundary conditions were specified at the outlet
T (end) = T (end-1)
which works fine by using the temperature values of the previous node.
Thanks.
lost.identity is offline   Reply With Quote
a simple Boundary condition question prapanj OpenFOAM Running, Solving & CFD 1 March 16, 2009 08:51
Slip boundary condition what is inside normunds OpenFOAM Running, Solving & CFD 2 June 4, 2007 07:45
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
simple question about fan boundary condition Jane FLUENT 0 June 24, 2004 17:40
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
