July 9, 2004, 13:53 |
Two phase +VOF
I am currently working on a problem that requires the simulation of a fuel injection sytem in a inlet port. I would like to know if it is possible to link the continous and discrete simulation,to a VOF in Fluent
I am trying to simulate the fuel particle interaction with the fuel film created on the inside of the port Any help would be appreciated as I have come to a stop on this! |
July 19, 2004, 11:37 |
Re: Two phase +VOF
It is not possible to link the two through traditional methods. As you have probably seen, the 3 methods for solving continuous multi-phase flows are not capable of solving for particles. These are similar to most HMP models. To look at particles, you need to come up with some sort of dynamic model that has to be linked through the UDF's and source term methods. I did something similar for water and fuel, looking at fuel droplets (see Badeau, A.E (2000) "A droplet formation and entrainment model for stratified, liquid-liquid flows.") However, I would not recommend using FLUENT for this job, maybe if you could get FLOW3D, it would be better.
July 28, 2004, 05:46 |
Re: Two phase +VOF
I want to get the information about "Two phase +VOF"
August 3, 2004, 09:42 |
Re: Two phase +VOF
Try this code I used for my postDoc on spray atomization: http://www.nabla.co.uk/main/mainhe30.html#sprayBreakup
It should be able to do what you want and its free. |
Volume fraction of dispersed phase to determine DPM, VOF, Mixture model | Mohsin | FLUENT | 5 | March 5, 2018 08:47 |
Extract primary phase thread in VOF with 3 phases | Eric | FLUENT | 2 | July 7, 2011 03:22 |
VOF for single phase? | vuccj7 | FLUENT | 0 | April 20, 2011 20:59 |
Differences between VOF and phase field | 2L | Main CFD Forum | 2 | July 4, 2004 14:30 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
