Mesh/Cell size
Old   July 8, 2004, 06:42
Default Mesh/Cell size
Jamcam
Hi all,
Can anyone tell me if there's a rule of thumb for defining the cell sizes of your mesh. I realise this is dependant on the flow type, etc. Is there a way to calculate a reasonable cell size based on flow conditions, for instance?
Jamcam
Old   July 8, 2004, 07:05
Default Re: Mesh/Cell size
Maciej Matyka
You should satisfy the CFL (Courant - Friedrich - Lewy) stability condition to be sure to have stable solution and choose apropriate cell size.
However, the cell size will determine size of your time step, so be carefull to be sure to satisfy CFL criteria. It also strongly depends on type of the flow you are trying to simulate - give some hints: is that compressible/incompressible flow? what discretization scheme for convective terms are you using? etc. etc.
Best, Maciej Matykahttp://panoramix.ift.uni.wroc.pl/~maq/eng/
Old   July 8, 2004, 17:01
Junseok Kim
For the multiphase fluid flow, you need a sufficient fine mesh to resolve surface tension force, for example. Finer mesh is better, but it costs a lot, so you need to trade off both.
Junseok
Old   July 9, 2004, 00:52
Apurva
For Viscous flows, visit this web-site
http://geolab.larc.nasa.gov/APPS/YPlus/
Apurva
Old   July 9, 2004, 03:28
matej
Hi Jamcam,
I'm afraid, the mesh size is more calibrated estimation, guess and intuition.
If you're doing incomressible steady state, you can easily leave CFL sleeping in the corner. There are, still, some good advices:
(1) boundary conditions -inlets/outlets - you need some cells to push the mass through, so at least 4-8 cells across.
(2) fine mesh in places with steep gradients
(3) watch the Y+
(4) do grid-dependency test.
Cannot dig any other out of my mind now.... There is one thing, I've found - finner mesh on outlet/pressure bounday will help the convergence, believe it or not, its working for me. You are -anyway always limited by the memory and CPU time.
matej
Old   July 12, 2004, 09:43
Jamcam
Thanks for all the input, guys!
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
