6 Degree of Freedom Navier Stoke Equations
Old   July 5, 2004, 06:32
Default 6 Degree of Freedom Navier Stoke Equations
Apollo
Hi. Can I seek some advice about a CFD problem??? I might be doing a project, which involves 6 Degree of Freedom Navier Stoke Equations. This means that the CFD problem has the fluid flow and solid body motion solved simultaneously. The fluid flow influence the motion of the solid body, while the solid body motion influence the fluid flow. Can this be solved using FLUENT software? Currently, I know that in FLUENT solver, the motion of the solid body is fixed arbitrarily and then we find the fluid flow field. But in actual situation, the fluid flow field will influence the solid body motion and in turn influences the fluid flow. Besides using Fortran programming, what other software can I use to do that problem??? Is there a new version of FLUENT software coming up whereby I can do this fluid structure interaction (the fluid affect solid body motion, solid body motion affect fluid. But are solved simultaneously).
Old   July 5, 2004, 09:49
Default Re: 6 Degree of Freedom Navier Stoke Equations
hazim saob
dear sear Iwant to learn everything about turblentflow since ineed it to my research .
hazim saob
msc powerengineerig
Old   July 5, 2004, 18:29
Junseok Kim
Theere is one way to do that work. You can use multi-phase fluid method, and take the solid is very viscos fluid, 1:10000, then you will see the both effects, i.e., solid affect fluid, and vice versa.
Junseok
Old   July 6, 2004, 16:07
4xF
Take a look to the CD adapco website. There are people doing this kind of stuff for years now (i.e. floating bodies, etc...): www.cd-adapco.com or www.adapco-online.com
Old   July 6, 2004, 17:56
just_curious
Solid material properties like Young modulus and Poisson dilatation coefficient can be obtain supposing solid is a very viscous fluid ? Is it possible ? Can you explain, please ?
Thx
Old   July 6, 2004, 20:39
Junseok Kim
I don't know about that detail, but what I suggested was one of numerical tricks for dealing moving objects which influences the flow and are influenced by the flow.
Junseok
Old   July 21, 2004, 17:46
Serguei
FlowVision + ABAQUS can solve this problem, there is an interface between
Navier Stokes equations in rotation frame..? vinayender Main CFD Forum 2 December 1, 2009 01:12
degree of freedom ztdep Main CFD Forum 1 January 12, 2009 09:16
Navier Stoke eq. for Sliding Mesh technique Jackie Main CFD Forum 1 July 3, 2006 12:47
Navier Stoke eq. for sliding mesh technique Jackie FLUENT 0 July 1, 2006 03:42
6 Degree of Freedom Navier Stoke Equations Apollo FLUENT 0 July 5, 2004 06:34
