Multigrid method for Lax-Wendroff scheme
Old   June 30, 2010, 12:02
Default Multigrid method for Lax-Wendroff scheme
Samira
samira is on a distinguished road
Hi everyone,
I am working with an in-house compressible Navier-Stokes solver which uses the one-step second order Ni's lax-Wendroff scheme.
For accelerating the convergence, I am trying to implement the multigrid in the solver. Actually, in Lax-Wendroff method, because of the coupled descreatization of time and space, the algorithm is a little bit different from explicit multistage codes. It is actually called "multiple-grid" in Ni's first paper.
I just wanted to find out whether anybody have any experience or information about it because it does not seem to be working in my code.
I know this topic has been closed almost 30 years ago and that makes it even more difficult because I can not find anybody alive in the authors to contact.
Thanks.
samira is offline   Reply With Quote
Old   July 2, 2010, 23:17
jed
Jed Brown
jed is on a distinguished road
You can write you discretization in semi-discrete form (discretize only over space, not time). This is greatly preferable from a software perspective since you can use any SSP method for the forward integrator, and can naturally solve for steady states. Once you have a semi-discrete form, you can use pseudotransient continuation (http://www.cs.odu.edu/~keyes/papers/ptc03.pdf) in Newton-Krylov or nonlinear multigrid form to solve for steady state.
jed is offline   Reply With Quote
Multigrid Method for Euler Equation Vidhyashankar.N Main CFD Forum 2 March 23, 2008 22:14
Multigrid method Suresh kumar Main CFD Forum 1 April 24, 2006 21:07
Pressure Possion equ.and multigrid method Tony Main CFD Forum 16 April 28, 2001 13:08
Unstructured Multigrid Method for Euler equations Jian Xia Main CFD Forum 8 December 20, 1999 13:31
