VOF fluxes not balancing even it's converging..urgent please!!! |
June 18, 2010, 17:05 |
eers
Rep Power: 17 |
HI all
I am using 3D VOF steady state implicit solution (i don't need unsteady at this point) and I run the solution and it took more than 5 days to converge (the residual limits are in the range of 10^-6). The problem here is the fluxes are not balancing. Secondary phase (water here) has not yet reached outlet and primary phase (air) is showing some reverse flow at the outlet. what does it mean without mass flow rate balancing, even though residuals reached to such low levels. I wonder it works if I use implicit unsteady solution. Also I started wid high velocities at the inlet to fill the inside domain wid water and reduced eventually to actual velocity. I allowed more time to dispose the already filled water towards the exit (pressure outlet) but it seems it's still showing lot of liquid at the entry though the convergence has already reached. Any suggestions please!!! appreciate for your valuable suggestions thanks Regards eers |
June 21, 2010, 11:14 |
eers
Rep Power: 17 |
No one here to answer!!!!!
July 10, 2010, 05:50 |
Claus Meister
Rep Power: 18 |
What did you do to measure this!
July 11, 2010, 01:36 |
eers
Rep Power: 17 |
Report-> fluxes->inlet & outlet( for individual phases)..
July 11, 2010, 05:39 |
Claus Meister
Rep Power: 18 |
Okay! I think you do not use OpenFoam, do you?
July 13, 2010, 15:56 |
eers
Rep Power: 17 |
i am using FLUENT 6.3.2
plz rply urgent regrding vof model for my system | garima chaudhary | FLUENT | 1 | July 20, 2007 09:37 |
urgent query regarding vof model plz rply | Garima Chaudhary | FLUENT | 0 | July 13, 2007 03:20 |
urgent help too many VOF subtime steps error | sudheer | FLUENT | 1 | January 24, 2007 01:16 |
URGENT HELP: Too many vof sub-timesteps | lamlash | FLUENT | 2 | July 31, 2006 15:54 |
Urgent! Access violation of UDF using VOF | Rucy | FLUENT | 0 | January 9, 2006 05:01 |
