entropy fix
Old   June 22, 2004, 14:11
Default entropy fix
autofly
the entropy fix is necesary for Roe-fds in supersonic flow.Harten' YEE'S formula is popular and used widely. but every author do some modification to it. such as the turn-on factor epslon. lamda1= U,lamda2=U-C lamda3=U+C, lamda1,which is modified with a smallest epslon only in stagment region.on contrast, lamda2,lamda3 is modified with epslon = eps*max(abs(lamda3),abs(lamsa2)). now i meet some other methods to define the epslon, such LAURA code's method.I want to get some information about the method which is used in CFL3DV6, because i get some information about it's entropy fix result in cfl3d web http://cfl3d.larc.nasa.gov/Cfl3dv6/c...w.html#precond. i want to get the detailed method of cfl3dv6, because of its easyness
Entropy jump across shocks Dave Main CFD Forum 8 March 12, 2008 11:21
roe solver with entropy fix mehdi Main CFD Forum 1 February 26, 2006 06:36
entropy fix for Riemann problem vivek kumar Main CFD Forum 3 August 31, 2005 08:47
limiter & entropy fix of Roe scheme kei-tee Main CFD Forum 21 May 26, 2003 06:50
entropy fix and subiteration zhaohuiyong Main CFD Forum 3 April 12, 1999 06:51
