June 15, 2010, 02:32 |
RMS Courant Number vs MAX Courant Number
MG
Rep Power: 17 |
Hi all,
sorry for confronting you guys with such a stale topic. I thought when everybody is talking about the Courant Number, such as CFL has to be less than 1 etc. ... it is addressed to the max Courant number. Now I've read the following sentence in Ansys CFX, 12.1 Help: "For accuracy, the average Courant (or CFL) number should be in the range of 0.5-1. " What does it mean? Do I have to consider the RMS Courant number. Help will be appraciated Thanks in advance. zzz |
August 19, 2010, 10:38 |
Freddie Sizer
Rep Power: 17 |
This is related also to mesh size.
Since the courant number is calculated using dx (distance between cell centre or interface depending on solver) what this means is that in regions where the flow is fast you need smaller cells to achieve the courant number value of between 0.5 and 1. |
June 11, 2012, 02:24 |
Hi
Danial
Rep Power: 15 |
IN my transient simulation of homogeneous multiphase problem involving free surface also, i have RMS courant Number = 0 , Max Courant nUmber = 0 , is it OK??? If not what could be the problem??
Thanks |
June 12, 2012, 14:44 |
Rep Power: 17 |
Accuracy and stability. If you use an explicit scheme and violate the CFL condition then stability should suffer. However the Courant number should be as close to unity as possible for accuracy. When it comes to accuracy then I guess that you could use an average value for the entire mesh.
"Trying is the first step to failure." - Homer Simpson |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
