Air flow in hard disk drives
Old   June 16, 2004, 22:58
Default Air flow in hard disk drives
Sundar
Dear Friends,
I am about to start researching the turbulent air flow characteristics in a hard disk drive using CFD. In this connection I invite advices and suggestions on the turbulent model to be used here. Also let me know if there exists any literature that provides validation for numerical studies conducted on this problem.
Cheers Sundar
Old   June 17, 2004, 04:53
Default Re: Air flow in hard disk drives
Junseok Kim
https://dspace.mit.edu/retrieve/3785/HPCES018.pdf
and look at the references therein
Old   July 10, 2004, 03:14
benzi John
Old   July 10, 2004, 03:20
benzi John
I will be involved in flow and particle simulations in a Hard disk drive. Of special interest is the microflows in the head-disk interface and coupling pariticle methods in such region to any macromethod like FLUENT. Can any one help me in giving some ideas as to the micro method to be used and coupling with a macro method?
Benzi
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
UDF, air flow through a cell----get velocity in lig FLUENT 0 September 6, 2010 14:02
Air flow on a pipe gulbenkian FLUENT 1 June 8, 2010 08:31
Air flow over a cylinder momentum_waves Main CFD Forum 1 November 17, 2008 21:54
Hot rod in transverse air flow Anders Larsson Main CFD Forum 3 April 19, 1999 10:28
