About Residual Distribution Schemes and Local Preconditioning for Unstationary NS Eqns.
Old   July 29, 1998, 05:51
Default About Residual Distribution Schemes and Local Preconditioning for Unstationary NS Eqns.
D.A. Caraeni
Hi everybody in CFD!
I'm currently involved in testing my own code, Navier Stokes solver, FV, unstructured grid, using a Multidimensional Upwind Scheme (Matrix Distribution Schemes, like: Narrow, SUPG and LW). For turbulence modeling, I intend to use the LES concept. I will finish testing the laminar solver and implementing one or two SGS models inside my code before Dec. this year. Finally I intend to have a parallel version of my code before June 1999.
My first question is, if there is anybody having experience in this field willing to share these knowledge's with me. I know some Ph.D. students and Professor Deconinck at VKI and Professor Phil Roe and co. at Michigan University are doing almost the same things, but I have no contact with them.
For the unstationary problems (turbulent flow, means always unstationary!) I use a Jameson type scheme and the same kind of (pseudo) time marching scheme as for the stationary (stationary inviscid or laminar viscid flow) case. Therefore, I am also interested if there is anybody that has some experience in preconditioning methods for unstationary NS equation and for NS equation including source term (like centrifugal force and Corriolis force terms for instance).
(I know the work of Van Leer, D Lee, Phil Roe from Michigan, and the experience that they have in preconditioning for stationary NS equations!!)
Looking forward hearing from you,
Yours, D. Caraeni
Ps. "A nice day" everyone.
Old   July 29, 1998, 09:54
Default Re: About Residual Distribution Schemes and Local Preconditioning for Unstationary NS Eqns.
Farid Moussaoui
Hi, You can found many publications on FS schemes on the web page of the CFD lab at michigan.
http://www.engin.umich.edu/research/...lications.html
Farid.
Old   July 29, 1998, 10:42
D.A. Caraeni
Thank you Mr. Moussaoui for your kindness.
Yes, I know those papers (dissertations) of Lisa Messaros, Dohyung Lee, George Tomaich, and others. I was thinking to found some "real persons" that are now currently involved in research in the Residual Distribution Schemes or Local Preconditioning for Unstationary NS field, and to directly discuss with them. Which is the state-of-art, at the level of year 1998, in this field. There are any new publications(late 1997-1998)? Anything new about a new Matrix Distribution Schemes? Is there any solution to "fix" the convergence stability problems of the original matrix-PSI scheme? Any new solution for a high order scheme suitable to use also for NS problems (here I cannot use the HE decomposition!)?!
Sincerely yours, D. Caraeni
Old   July 30, 1998, 15:23
Farid Moussaoui
There is an extensive research on FS schemes at VKI. You can see the VKI lectures series. VKI LS 1995-02 and VKI LS 1997-xx on CFD. You can also see the state-of-art in the volume booktitle = {Euler and Navier-Stokes Solvers Using
Multi-Dimensional Upwind Schemes and Multigrid
Acceleration}, editor = {H. Deconinck and B. Koren}, number = {57}, series = {Notes on Numerical Fluid Mechanics}, year = {1997}, publisher = {Vieweg Verlag},
I hope that this help. Farid.
Old   July 31, 1998, 05:55
D.A.Caraeni
Dear Mr. Moussaoui,
Thank very much for your advice and help. These book, that you've indicate me, should be of real help for me. I will try as soon as possible to order it. Meanwhile I've found on internet some other references very interesting for me, but nothing about local preconditioning for unstationary NS. I have some results on that but not completely satisfactory and I wanted to see if there is also somebody else working on these topic, to exchange ideas. Thank you again for your help,
Sincerely yours,
Doru Caraeni
Old   July 31, 1998, 06:09
Farid Moussaoui
There is a web page on preconditioning maintained by Kleb at Nasa. I think it is very usefull. For the preconditioning of the Unsteady NS, you can see the work of Viozat at INRIA. She works with the Roe scheme, and all what she does is to precondition the artificial viscosity in the numerical fluxes without the special treatment for other methods of precondioning where accuracy in time is lost.
Oups, the preconditiong web page is
http://ab00.larc.nasa.gov/~kleb/precond/
Old   July 31, 1998, 11:36
D.A.Caraeni
Dear Mr. Moussaoui,
The information's that you've give me were extremely valuable. In these two day I've found (due to your help) a lot of informations in the problems that I'm interested. Thank you very much for your help!
With esteem, Doru Caraeni
Ps. My web page is:
http://www.fm.vok.lth.se/FM/Doru/doru.html
and it contains some informations about me.
Old   August 5, 1998, 08:31
M.A.Olshanskii
There is a number of recent results for the preconditioning of incompressible N-S flows, if you interested...
Best.
Old   August 7, 1998, 13:04
Aldo Bonfiglioli
Dear Dr. Caraeni, as you were asking in a previous post about people involved in the study of residual distributions schemes, this is my home page:
http://www.unibas.it/utenti/bonfiglioli/www.html.
which is a little bit outdated, but still gives an overview of my activity.
Concerning preconditioning, (H-E splitting), to my knowledge this remains a problem whenever one encounters stagnation points. The only viscous computation I've seen using H-E involved a Mach=2. Re=106 flow over a NACA 0012, where the physical dissipation was probably enough to make things work. However, I have to admit I'm also out of date about preconditioning, so there might have been progresses I'm not aware of.
Using matrix distribution schemes, however, you should be able to solve the unsteady eqns. without H-E splitting (no preconditioning) which shouldn't be too much of a problem unless you're solving for very low Mach numbers.
Regards, Aldo Bonfiglioli
rhoPisoFoam stability problems at low Mach ivan_cozza OpenFOAM 1 October 1, 2010 12:03
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 06:55
Errno 24 linux ivanwhlau OpenFOAM Running, Solving & CFD 6 July 1, 2009 11:16
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
Problem with jet flow braennstroem OpenFOAM Running, Solving & CFD 16 May 15, 2006 03:23
