CFD in turbine
Old   June 13, 2004, 22:58
Default CFD in turbine
Den
Hello, Guys:
We gonna do some simulations on gas turbine. But I don't have any experience. Can someone tell me where I can find some basic information about CFD in gas turbine? like what turbulence model I should use? How to deal with the moving grid? how to simplify the gas turbine (simulation model)? where I can find some experiment data so I can compare with numerical simulation? what is "casing treatment"? And is there any free code available for gas turbine? I think develop a new 3-D N-S solver is too much for me. Modified some existed code is the most efficient way to get the job done.
Thank you in advance!!!
Old   June 14, 2004, 09:44
Default Re: CFD in turbine
Apurva
Hi
For Refrence, refer B. Lakshminarayana Book on Turbomachines. (Refer the Book Section of this site).
If you are in US, ADPAC is avialable refer :capella.colorado.edu/~laney/softint.htm
Look for paper by Prof. Dawes, Denton. One issue I remeber is 1992 Journal of Turbomachines.
Experimental data are avilable from : http://ercoftac.mech.surrey.ac.uk/
I have worked in the same field, developed my own sliding mesh code during my Masters.
Good Luck
Apurva
Old   June 14, 2004, 12:54
amol palekar
Hi, Are there any 2-d results available ? amol
Old   June 14, 2004, 13:09
Apurva
Yes,
1991, Int. Journal of Numerical Methods in Fluids. Details, I can give you tomorrow
Old   June 14, 2004, 16:47
jerry
thank you very much!!!
......I am at US but not a citizen, damn ADPAC has export control.
http://ercoftac.mech.surrey.ac.uk/ I only see two set data of experiment for boundary layer. Did I miss something?
thanks a lot
Old   June 14, 2004, 18:42
amol palekar
thanks. that will b gr8
Old   June 14, 2004, 23:38
Den
Thank you!
Can you explain how you do the sliding mesh? Thanks
Old   June 18, 2004, 12:47
kamesh
Hi can u please briefly say abt ur sliding mesh (generation and applying etc). bye kamesh
Old   June 19, 2004, 04:10
Apurva
It was an algorithm developed by me. To descibe here it is very difficult. It was based on interpolation of intermediate grid point between 2 sliding block after it has rotated. Then the fluxes where calculated using the properties of two adjacent cells of both the blocks and the common area between the two cell. Hope it helps.
If you are interested in the my Masters Thesis. You can get a digital copy of it from library of IIT Bombay. The webaddress is :www.library.iitb.ac.in
Regards
Apurva
Old   June 19, 2004, 04:12
Apurva
You seem to be located in India. If yes , provide me your Address; I can post you relevant pages.
Regards
Apurva
Old   May 7, 2012, 02:25
Reza khodadadi
reza_65 is on a distinguished road
Send a message via ICQ to reza_65 Send a message via AIM to reza_65 Send a message via Yahoo to reza_65
Originally Posted by Apurva
;29561
Regards
Apurva
Dear Apurva
could you please email your thesis for me? your link dose not work anymore
Email: Reza.khodadadi@modares.ac.ir
many regards.
khodadadi.
reza_65 is offline   Reply With Quote
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
Helical Turbine CFD gkadoo Main CFD Forum 0 April 22, 2010 04:28
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
francis turbine with cfd nizam Siemens 1 July 15, 2000 20:11
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
