Standard K-Epsilon TO Reynolds Stress calculation (for convergence)
Old   May 22, 2010, 08:09
Default Standard K-Epsilon TO Reynolds Stress calculation (for convergence)
Walid JARRAH
wjarrah is on a distinguished road
Send a message via MSN to wjarrah Send a message via Skype™ to wjarrah
Hello everyone,
I'm having problems to make the reynolds stress turbulence model converge (The scaled residuals stay between 10-2 and 10-3. So I thought about starting the calculation with a standard k-epsilon and then switch it to Reynolds stress when converged enough.
I started a calculation with the standard k-epsilon model, the residuals are between 10-6 and 10-7 and are still decreasing , should I wait till they become constant before switching to Reynolds stress, or can I switch it right now even if the residuals can still go smaller ?
Thank you for your help
wjarrah is offline   Reply With Quote
Old   May 27, 2010, 06:29
Default Hi
Dynampally Pavitran
pavitran is on a distinguished road
  1. Output the parameters which are important to your simulation and monitor them. For ex: Lift for an airfoil.
  2. If they are not changing any more or falling in the required tolerance limit then your simulation is ok and you can proceed with RSM model.
pavitran is offline   Reply With Quote
Old   May 27, 2010, 06:32
Walid JARRAH
Ok thanks !
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 01:01
Reynolds Stress Models Jade M Main CFD Forum 0 April 21, 2010 17:38
Reynolds stress calculation from k-epsilon model Sae woong Kil CFX 2 December 4, 2008 18:59
Reynolds Shear Stress calculation ND Main CFD Forum 1 August 3, 2008 05:12
Warning 097- AB Siemens 6 November 15, 2004 05:41
