Explicit Pressure Based Scheme
Old   June 1, 2004, 13:38
Default Explicit Pressure Based Scheme
Apurva
Hi
Till now what ever pressure based scheme I have read are implicit, are there any explicit pressure based scheme.
Thanks
Apurva
Old   June 1, 2004, 13:52
Default Re: Explicit Pressure Based Scheme
Li Yang
Really ?
if you read Versteeg's book, it tells you what is the explicit scheme on page 171, and then the Crank-Nicolson scheme and the fully implicit scheme on the subsequent papges.
Li
Old   June 2, 2004, 22:52
Mordorgie i grodrom
So how do you couple the pressure-velocity in case of an incompressible fluid?
Do you use the old pressure field to calculate the new velocity field and then adjust the pressure field afterwards?
Best Regards
Old   June 3, 2004, 05:47
CFD Learner
Correct. You can read Versteeg's book. In page 142, it states that an initial pressure field is guessed....
Regards
Li
Old   June 3, 2004, 21:01
Mordorgie i grodrom
SIMPLE alghorithm p.142.
Ok since my maths aren't my strongpoint I might be wrong here, but doesn't that make the calculation quite implicit (i.e. you dont't use all known values to calculate for instance x-velocity component in a node at a higher time-level)?
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
Pressure vs. Density based jan FLUENT 2 May 3, 2007 04:45
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
Pressure based and Density based Solver Xobile Siemens 1 November 30, 2004 22:13
