May 31, 2004, 10:25 |
Radiation and Symmetry
Hi all,
Can anyone tell me if the radiation models are realiable when using symmetry? As the radiation models are based on reflection, can fluent account for radiation that may cross the symmetry axis? For example a cylindrical furnace using symmetry along the longitudinal axis. Thanx Eric |
May 31, 2004, 11:02 |
Re: Radiation and Symmetry
Eric,
I cannot comment about fluent treatment of symmetry for radiation as I have never used it. However, any radiation solver implemnting specular reflection may be used to simulate symmetry. Symmetry surface is merely a perfect specular reflector. For the axis of a cylinder, the approach I use (FVM) naturally treats this zero area surface (any finite flux results in zero power for zero surface area). I hope this helps, Rami |
June 3, 2004, 07:55 |
Radiation models solve intensity(I) for each grid point and direction. if possible, print the intermediate intensity values in the domain for a sweep. If symmetrical boundary condition is implenmeted correctly, at the symmetry axis incoming intensity should be equal to out going intensity with a different sign. Here is the bc
I_m = I_mī where m : incoming direction mī: outgoing direction There are simple test cases available in the radiation heat transfer books for cylindrical media. Quickest way: Radiation model provides source term to energy equation. if you donīt see any non-symmetric temperature profile along z axis it means that it works. Nuray |
June 3, 2004, 08:30 |
Thanks nuray and Rami
error radiation model monte carlo | andro | Main CFD Forum | 1 | February 2, 2012 10:20 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 05:53 |
Incident Radiation | Nicki | CFX | 1 | April 17, 2009 09:18 |
radiation and symmetry | Mark | FLUENT | 2 | November 4, 2004 14:50 |
Radiation and symmetry | Eric | FLUENT | 2 | May 31, 2004 12:02 |
