Domain for external flow
Old   May 14, 2010, 03:17
Default Domain for external flow
chinc is on a distinguished road
I wish to raise some discussion points here on determining the best suitable type of domain shape for external flow. As we know, always there will be questions on "how large" or what should be the extend of domain size for external flow.
Typically there are a few approaches available:
1. to use a rectangular box with the size extended 5 to 10 times the characteristic length of the geometry/ object under simulation.
2. to use a sphere enveloping the object under simulation
3. to use a semi sphere
The later two (2. and 3.) are said good to eliminate some edge effect at the corners of the domain which happens in 1.
Does anyone has any experience with this method of modeling? Appreciate to receive some comments/ opinions/ advice from the fellow experts in CFDOnline.
Thx & Cheers
chinc is offline   Reply With Quote
Old   May 14, 2010, 12:37
Chris
Chris D is on a distinguished road
Thx & Cheers
I'm definitely not an expert, but this is what I usually do:
I think blocking this way allows more control over the grid density. (I color-coded the edges to show what I mean. The edges with the same color would have the same grid density.) Also, it keeps the boundary layer grid from extending into the far field, reducing the total number of gridpoints.
Chris D is offline   Reply With Quote
Old   August 8, 2010, 02:23
Question Domain for external flow
Ramakrishnan Ramaswamy
aerosuresh is on a distinguished road
Hi friends, can anyone help me how to fix a domain for external flow. I am analysing flow over a swept wing. Can i choose a circular domain or rectangular one or oval shape, What is the significance one over the other?
aerosuresh is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Porous domain in a flow field rikio CFX 7 August 25, 2009 23:39
Domain for Pipe Flow Swarup FLUENT 0 September 29, 2005 00:25
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 03:19
