Easy question
Old   May 21, 2004, 03:51
Default Easy question
Confused
I have flow through a nozzle (circular pipe) and want to calculate Re-number. Is it correct to use the radius of the nozzle as the characteristic length?
In Fluent it seems like I should use the diameter and not the radius (6.2-2). In Malalasekera and Versteeg it is stated that radius is to be used (page 72).
Cheers!
Old   May 21, 2004, 11:45
Default Re: Easy question
versi
Both Radius and Diameter are OK. really simple.
Old   May 21, 2004, 23:26
Confused
Ok. Correct me if I'm wrong, but the radius is used when you have axial symmetry and the diameter is used otherwise?
Old   May 22, 2004, 01:01
Reynolds
In Re number you can set even length from your object to Moon, will be no problem. In this case just scale will be changed. If you want to use some empirical formula from literature, you need to know which dimenstion was used during those experiments.
Old   May 22, 2004, 03:14
Confused
Ok but this is kind of the problem here. As I stated in the first post there are two different values of L used for the same type of empirical formula.
1. Re = U*L/v 2. l = 0.07 L 3. I = 0.16(Re)^(-1/8)
4. k = 1.5(U*I)^2 5. e = Cnu^(3/4)*k^(3/2)/l
Here l is the turbulent length scale and L is the characteristic length. Using the above equations I will get two different BC values for k (and e). One value according to the diameter and one according to the radius....
This might seem all very simple to you, to me it's not. Please tell me what value you should have used in order to calculate the inlet BC for a pipe of radius r and diameter d.
Thank you for your replies.
question about uds tanven FLUENT 2 July 5, 2015 12:22
Unanswered question niklas OpenFOAM 2 July 31, 2013 17:03
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 21:31
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
Question on Sediment Mass Conservation Scheme Wen Long Main CFD Forum 0 July 6, 2004 16:45
