Ashish D. Shah
Rep Power: 0 ![]() |
I am performing 2D axisymmetric simulation of flow in pipe. I prep the initial mesh in gambit and have aligned the axis to the X-axis, prepared a simple Quad Map mesh and then exported a 2D mesh. After importing it in Fluent, i checked the mesh and the minimum volume was +ve. I switched on axisymmetric mode under solver, then again checked mesh, it shows a -ve volume. What can be the reason? |
Rami Ben-Zvi
Rep Power: 17 ![]() |
For axisymmetry you should make sure the radius is non-negative, otherwise negative volumes may be created.
axisymmetric solver, negative volume |
Axisymmetric Vs 2D Flow problem | nikhil | FLUENT | 0 | March 30, 2010 00:52 |
boundary conditions for axisymmetric problem | eers | Main CFD Forum | 0 | June 19, 2009 15:52 |
problem with developing new LES solver | Edison_Ge | OpenFOAM | 2 | June 18, 2009 02:26 |
CFX 11 x64 solver? problem | Attesz | CFX | 6 | June 7, 2009 09:37 |
Can I use coupled solver for this problem | Frank | FLUENT | 0 | April 11, 2006 07:28 |
