Gambit mesh export
Old   May 18, 2004, 17:59
Default Gambit mesh export
Satya
Hi ALL,
I was hoping that somebody could answer this question. Basically I generated a mesh in Gambit and now I am trying to output it into a neutral format (Generic neutral) so that I can read the same mesh into CFX-Pre through the PATRAN Neutral format. I cannot do it. Is there any other way I can export the gambit mesh so that I can read it into CFX-Pre??
Thanks Satya
Old   May 26, 2004, 18:06
Default Re: Gambit mesh export
xueying
Is neutral format means the format with extension .neu? If yes, I've been always exporting mesh from GAMBIT to .neu format, and it doesn't show any problem if I choose solver in GAMBIT appropriately. I choose POLYFLOW as solver in GAMBIT; and I remember in last version of GAMBIT I used other solver which doesn't give .neu in the current version so I switch to POLYFLOW.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Export Edge mesh in Gambit mecipema ANSYS Meshing & Geometry 3 February 16, 2011 09:20
Problems with gambit mesh lions85 FLUENT 2 August 28, 2009 20:05
export or convert gambit mesh to CGNS zaidun FLUENT 6 April 20, 2006 05:48
GAMBIT merge and export mesh sean FLUENT 4 March 8, 2001 08:50
