Natural gas combustion
Old   May 17, 2004, 09:19
Default Natural gas combustion
Newbie
Hi all,
Just getting started on natural gas combustion in a melt furnace. Can anyone tell me if I can simulate the natural gas combustion with the methane/air database in fluent, thereby effectively simulating methane/air but with acceptable result for natural gas conbustion?
I think I might be able to do this as the natural gas contains 94% methane??? But not sure if this is appropriate for CFD simulation?
If I can do this, could someone give me a reference?
Thanks
Tom
Old   May 18, 2004, 03:33
Default Re: Natural gas combustion
matej
well I'll give you a typical scientific answer. It depends on what you want.
Be more specific in what are you after. Is it temperature field? Is it concentration of CO,NOx? Is it premixed or diffusion combustion?
matej
Old   May 18, 2004, 04:36
Newbie
Hi matej,
It's diffusion combustion I'm simulating using the two-step eddy dissipation model. An overall picture of what is going on inside the furnace is what I want.
I want to gain an understanding of what is going on inside the furnace. The property values don't have to be exact (although that would be nice) but the flow field and combustion trends must be right. The understanding gained is used to design a control system, so the flow patterns are important to us.
Thanks for your help,
Tom
Old   May 18, 2004, 05:02
matej
If you want an overall picture, temperatures and velocity field, your two step eddy dissipation model is a good start. eddy dissipation models convergence is quite good. It will give you the basic idea what is going on. The concentration of main products like H2O and CO2 would be OK. Don't expect to have correct CO and NOx. It's OK to use it for your natural gas. Just do not forget to have the same power in the furnace.
matej
Old   May 18, 2004, 05:56
Newbie
Thanks matej,
What do you mean by 'do not forget to have the same power in the furnace'? Do you mean, that if the furnace is operating at 30MW for example, that the simulation should also be at 30MW?
Also, do you know of a paper that simulates methane combustion to represent natural gas, so that I can reference it?
Thanks again,
Tom
Old   May 18, 2004, 07:30
matej
Yes, I mean the same power. Your natural gas is not 100% methane.
You can find the papers at www.sciencedirect.com . There's also lot of ASME papers with industrial application of CFD.
matej
Old   May 18, 2004, 08:49
Newbie
Thanks alot matej, you've been a great help!
Tom
Old   May 22, 2004, 05:00
zxaar
hello, I have done lot of work with methane and natural gas combustion, i could be good help, better drop me an email on zxaar@yahoo.com, we can discuss this there in detail
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
combustion natural gas burner Jorge Chacón Hernandez FLUENT 4 May 26, 2010 08:03
Combustion of the natural gas Jiri Novak FLUENT 1 July 29, 2005 19:16
Natural gas combustion Newbie FLUENT 1 May 17, 2004 12:00
