April 27, 2010, 04:25 |
Wind Turbine Modelling Help
payam
Rep Power: 16 |
Hi all.
I want to simulate a vertical axis wind turbine in FLUENT6.3 but I have some problems about that.(I'm a rookie in CFD) Could you please tell me: 1- How should I calculate power coefficient (cp) of turbine in fluent????? 2- I want to do my calculations while the turbine rotates, so in boundary conditions I chose a number(for example 26 rad/s) as a rotational speed for my blades, is this a proper method???? I must mention that my simulation is 2d and I use k-e method. I would like to know if anyone has worked in a similar project and can help me now? Thanks for your reply. |
April 27, 2010, 11:53 |
wind turbine runs
#2 | |
2D runs with sliding mesh or MRF methods are pretty straightforward with FLUENT and the results are pretty good - computing force effects, pressure coefficient, predicting wakes (velocity deficit) etc. 1.Once you complete the run - go to reporting results and take a surface and view pressure coefficient. 2. For the Bound cond..yes, this value goes into the rotating reference velocity I will be posting some snapshots in my blog. Regards, CFDtoy Quote:
CFDtoy |
April 29, 2010, 12:30 |
payam
Rep Power: 16 |
Thank you very much CFDtoy, I gave the answer of my questions from your post but still I have some doubts about calculation of (cp)! How should I find that???
and may I have your weblog address pls?? |
April 29, 2010, 13:35 |
cp calc
Create surface (blade surface) and extract pressure coefficient? FLUENT lets you do it pretty straightforward. You will then have distribution of Cp over the surface and you can even create co-ordinates over the surface to check the Cp distribution.
CFDtoy Visit http://cfdtoy.blogspot.com
CFDtoy |
May 5, 2010, 03:30 |
payam
Rep Power: 16 |
Dear CFDtoy
I think my answer made you mistake! Cp in wind turbines is completely different from Pressure coefficient, it's POWER coefficient, so if I can find power of turbine or even torque of turbine I can find that. Would you please tell me how to find these two parameters. Thanks for your help very much. |
April 7, 2014, 17:45 |
vawt 3d
dhanish jose
Rep Power: 12 |
i am running a 3d simulation of vertical axis turbine.Te torque and the cp is not coming down and increasing over the tip speed ratios.Can some help me with this?
April 8, 2014, 04:37 |
venki
Rep Power: 15 |
Torque will oscillate in periodic form, check the BC , Domain size , interface etc.....
April 8, 2014, 12:53 |
dhanish jose
Rep Power: 12 |
Thankyou for the reply,But
my torque values are as follows tipspeed ratio torque 1 4 2 6 3 8 4 13 5 17 |
April 8, 2014, 14:11 |
#9 |
venki
Rep Power: 15 |
Take average for last 50 cycles.
please help in simulating a wind turbine blade in 6 DOF ????.... | usman naseer | Main CFD Forum | 2 | March 10, 2016 02:53 |
MOdelling wind turbine with CFX | moca | CFX | 2 | July 12, 2009 01:36 |
Wind turbine simulation | Saturn | FLUENT | 1 | June 16, 2006 02:12 |
Wind turbine simulation | Saturn | Main CFD Forum | 1 | June 12, 2006 03:57 |
Wind Turbine Modelling | Neil Campbell | Main CFD Forum | 1 | November 10, 1998 19:03 |
