Joule Heating Convergence applying Voltage
Old   April 25, 2010, 06:51
Default Joule Heating Convergence applying Voltage
Salik
salik87 is on a distinguished road
Dear all,
I am modeling a welding experiment in which Argon is used as a shielding gas, and Copper is used as the solid domain for electrode.
Argon gas starts conducting electricity at 12000 K , so I have inserted a heat source to heat the argon domain upto a value of 12000 K then I switch it off on the 50th iteration, now after that the Argon gas should start conducting electricity and should heat i.e. ( JOULE Heating effect) but the temperature falls down .
From what I understand is that the Copper electrode is not producing sufficient heat for argon to conduct, I have tried increasing and decreasing the voltage but it does not help. Some one please help me with this problem.
I have uploaded the Physics , the definition file and the results file. Please help me with this problem.
http://rapidshare.com/files/37992920...ating.zip.html
Thanks
salik87 is offline   Reply With Quote
Joule Heating Experiment salik87 Main CFD Forum 2 March 21, 2010 09:31
Joule heating convergence problem shahpar73 CFX 8 January 19, 2010 00:06
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
Joule heating and butler volmer rate in fluent swapna Main CFD Forum 0 March 12, 2008 14:09
joule heating bikash FLUENT 1 January 28, 2005 11:57
