HOw to match the Mach number in FLUENT??
Old   April 20, 2010, 07:34
Default HOw to match the Mach number in FLUENT??
applemango is on a distinguished road
How can i match a particular Mach number for simulating a case in FLUENT??
My BCs are:- mass flow inlet, pressure outlet..
I cant give velocity inlet as the inlet condition since my flow is rarefied compressible flow with nitrogen as the fluid..
THe cases which i hv simulated, im getting a difference between the experimentally calculated Mach no and Mach no from FLUENT..SO i want to match that..HOw can i do it??
applemango is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
The low mach number approximation in fluent Jamie FLUENT 5 October 7, 2015 10:15
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
compressible at low Mach number with uniteration ricklee Main CFD Forum 2 October 21, 2005 00:15
