Multiple flow inputs (FLUENT and GAMBIT)???
Old   April 15, 2010, 13:33
Default Multiple flow inputs (FLUENT and GAMBIT)???
Jonathan Servaes
JonEngineer is on a distinguished road
Hi.
Basically Im pretty new to CFD.
Im trying to model an insulation pack using the programs gambit and fluent but im having trouble setting up my model.
The pack consists of around 27 layers of foil with gaps inbetween and a coolant flowing along each of these channels.
My questions regard how to set up the model:
1) Can I use just 1 inflow for all the channels since it is the same coolant or should I make a different mass flow inlet for each channel?
2) when applying the thickness of each wall should i just create a wall in gambit and then define a thickness for it in fluent?
3) What mesh size/scheme should I use? Each channel is about 2.2mm wide and the length of the pack is 457.2 mm.
Sorry that I sound like such a beginner
Any help would be greatly appreciated. Thankyou very much
Jon
JonEngineer is offline   Reply With Quote
Multiple flow inputs (FLUENT and GAMBIT)??? JonEngineer Main CFD Forum 0 April 10, 2010 10:47
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 15:21
How to model suction flow in an airfoil in Fluent Davy FLUENT 4 October 23, 2006 04:56
Facing Few Problems in Fluent and Gambit Ravi Duggirala FLUENT 5 March 11, 2006 04:13
test cases for Fluent and Gambit Ben FLUENT 1 May 21, 2003 07:44
