3D centrifugal compressor simulation
Old   April 2, 2010, 23:08
Default 3D centrifugal compressor simulation
labib
nuimlabib is on a distinguished road
good morning everybody
at the present time. i am simulating the 3D centrifugal compressor. and i am still confuse to setting the boundary condition. so at the present i have the initial condition at the inlet is pressure and temperature. so i have to setting with pressure inlet. and if i setting in outlet with outflow. fluent give some caution that pressure inlet and outflow is not compatible. and then i set the outlet with pressure outlet. but i dont know what must i fill in gauge pressure in pressure outlet because my purpose is to get pressure outlet and mass flow rate in outlet. so i hope u can help me give me suggestion to solve this problem. and now i am still using MRF method. in further my simulation i will use the sliding mesh. but i dont know to setting this method.
please help me..
thanks..
nuimlabib is offline   Reply With Quote
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop olivier OpenFOAM 8 October 29, 2018 08:49
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 07:07
centrifugal pump and centrifugal fan Mangesh Main CFD Forum 3 January 3, 2006 12:21
stator-rotor interaction in the centrifugal pump G.H.Lee Main CFD Forum 4 May 25, 1999 08:33
