April 21, 2004, 12:18 |
SWE by RBF
Hi guys, I am new on this topic and have problems on setting the B.C. on the SWE ( shallow water eq ).When I run my code it goes well but after some step my water heights goes higher and higher ( it behaves still like a cosine function but with a high amplitude ).Thanks
April 22, 2004, 08:02 |
Re: SWE by RBF
Maybe you've forgotton to divide by 2 some central difference or a middle value .
April 23, 2004, 12:27 |
Re: SWE by RBF
It's better to let readers know what kind numerical scheme you use for solving SWE? And what do you mean 'higher and higher of h'? After a long long time, h will be still increasing to an unreasonalbe value?
April 23, 2004, 17:44 |
Re: SWE by RBF
collacation methods with r^3 rbf ( radial basis function ) .My problem is my h value is incresaing instead of having a nice sinusoidal shape( h value at the beginning )
December 2, 2011, 22:01 |
how to use RBFInterpolation
Zhang Haijun
Rep Power: 15 |
Hi
Now I am using OF-ext-1.6 do some work, I want to use RBFInterpolation. But I don't know how to used the RBF, and there are no such example about RBF. I will be appreciated if someone can give me a example about RBF. |
Released RBF motion solver | lr103476 | OpenFOAM Running, Solving & CFD | 6 | December 11, 2020 09:02 |
RBF motion solver does not work well in parallel | lakeat | OpenFOAM Bugs | 3 | August 8, 2013 06:50 |
Export mesh from Fluent in Nastran format | Wieland | FLUENT | 9 | October 19, 2012 10:16 |
RBF for Morphing | andrea.pasquali | OpenFOAM | 2 | December 5, 2011 06:10 |
SWE | PhD | Main CFD Forum | 3 | November 20, 2002 11:06 |
