Body Forces
Old   April 21, 1999, 11:04
Default Body Forces
Thomas P. Abraham
Hello Everyone:
I have a question on the dominance of body forces. In a given problem, Rayleigh number gives the strength of free convection.
When the Rayleigh number is more than 1.0e+7, we say that the turbulent effects need to be accounted. That does not necessarily mean that even the body forces are dominant too. Under what limit, the effects of body forces need to be accounted ?
Thanks,
Thomas
Old   April 21, 1999, 22:24
Default Re: Body Forces
Duane Baker
Hello Thomas,
1. Rayleigh No = Gr*Pr, physical meaning is the ratio of "Natural Advection" to diffusion terms in the energy (temperature) equation. Natural advection being the motion driven by the body force of bouyancy.
2. The analogy in forced convection is the Peclet No = Re*Pr and as you stated the influence and onset of turbulence is related to Pe for forced and Ra for natural convection.
3. How can one have a flow with a large Ra if the effect of bouyancy is not large (ie Gr is not large)??
To quote Eckert from p525 "Analysis of Heat and Mass Transfer": "A flow situation is called free- or natural convection flow when it is created solely by body forces."
Have a read through Eckert's discussion!
good luck!....................................Duane
Body forces on hovering airfoil sanmysterio Main CFD Forum 1 July 13, 2010 04:14
Fan modelling using body forces Fred Siemens 2 June 13, 2007 09:56
Fan modelling using body forces :specification Fred Siemens 1 May 4, 2007 08:40
strong body forces Ankan Main CFD Forum 0 August 2, 2005 03:13
Forces on spherical body Wen Long Main CFD Forum 0 June 29, 2002 22:21
