drag coefficient with k-eps model
Old   April 16, 2004, 06:38
Default drag coefficient with k-eps model
Mark
I'm calculating the 2D-flow over a NACA0015 profil with standard k-eps turbulence model. yplus values are between 20 and 100 along the chord.
I'm am looking for an explanation for the following observation.
Below stall angle the lift coefficient fits quite well to measurements. But the drag coefficient is far to high. At zero angle of attack some papers report a drag coefficent of approx. 0.0068. My calculated value is at 0.01.
I think I understood why I can't expect too much beyond stall angle, but what might be the reason for that difference in drag?
Best regards, Mark
Old   April 16, 2004, 10:03
Default Re: drag coefficient with k-eps model
ag
Are you running with wall functions? If not, then your value of y+ is much too large and your turbulence model is not modeling the boundary layer correctly.
Old   April 16, 2004, 11:39
Mark
Yes, I'm using the classical HighRe version with logarithmic wall functions.
Regards, Mark
Old   April 16, 2004, 13:08
Dynamic Edge
Check your Cp at suction side. It might be too high and contribute a lot to the drag, esp. at high AOAs
Old   April 16, 2004, 17:30
CFD Rookie
Mark,
what software are you using? Check the user manual on what is the range on y+ for KE turbulence model. Drag is always difficult to predict. There are lots of posts recently (either in main forum, CFX or in the fluent section) talking about this issue. I have been on this type of analysis for a few months now, and based on my experience, it is really really dificult to get computed drag as good as your computed lift. Y+ might be the main reason.
Check you Cp vs X/C plot. Normally the pressure side curve will match up pretty well, the suction side Cp, especially on LE area, is toughest to match. If your Cp vs x/c has good match w/ experimental value, and your drag is still off, then it means your pressure drag is good, but the friction drag, which is a function of you turbulence model, y+ etc is the main reason it is off.
By the way, what is your RE (chord)?
Old   April 19, 2004, 02:47
Mark
But shouldn't this error also affect the lift coefficient, which is quite well predicted in my calcuations?
Old   April 19, 2004, 02:48
Mark
Old   April 19, 2004, 03:12
Mark
My Reynolds Number is 10e7. I think the problem must be connected with the friction drag, since even at an angle of attack of 0 degrees my drag coefficient is approx. 60% to large. 0.01 instead of 0.006. I just checked again the y+ values for 0 aoa. y+ rises fast from 0 at the stagnation point to 110 at 0.15 chord. Then it drops almost linearily to 70 at the trailing edge.
Do you think that this values is to high and could be the reason for having 60% too high drag?
Regards, Mark
Old   April 19, 2004, 10:55
CFD Rookie
Lift is affected by y+ too, but obviously not as signigicant as drag.
Why don't you carry out a mesh dependency test. Refining or coarsening the mesh on the airfoil surface, thus gradually resulting in a lower or higher y+, then check your drag again. It is possible that with KE and standard (logarithmic) wall function the best drag result might not come from lower y+ values. Recall that y+ ranges between (approximately 35-350, this range depends on the code you are using). And the best drag result might come from any y+ values within the range.
I know this is not an easy task at all. On the other hand, besides the issue of mesh, you also need to make sure your domain is adequately big enough. Mesh on the wake region (directly after the trailing edge) must be fine enough. Check your residuals monitor and try to locate the cell (or node or element) with the highest residual value (if the code allows the users to do just that), then try refining the mesh at that location. For this type of flow analysis, result based on residual level of 1e-3 and 1e-5 might be quite different. Note that I am not indicating 1e-5 is adequate. Maybe to get proper drag result, you need to go an even lower residual. This is what I can think of other than the issues of y+ and mesh.
By the way, since we are on this subject, how close is your pitching moment result compared to the experimental values. Is Cm as good as Cl?
Good luck.
Let me know your latest progress.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
drag coefficient of cylinder Avijit FLUENT 12 April 23, 2017 04:26
Drag Coefficient for Ellipse Form (2D) Ketut Utama Main CFD Forum 8 December 11, 2014 12:03
same Drag Coefficient Amir FLUENT 0 March 5, 2009 11:28
Energy dissipation and Drag coefficient Freeman Main CFD Forum 10 January 27, 2006 08:42
