Help on project!
Old   April 15, 2004, 22:46
Default Help on project!
jacky
I reqired to create a 3D model and determine the air mass flow through the throttle body, which basically is a converging-diverging nozzle. what i did so far was created a cylinder as domain with the vol of the throttle deducted at the end of it, then i mashed with Hybrid/tri, then set the 3 sides of the cylinder as pressure inlet (1 atmo), the sides of throttle as wall and the end of the diverging section as pressure outlet. then i ran a inviscous flow model, but the solution diverge after 10 iterations and have floating point errors, also the velocity of flow is not right. can anyone explain to me what floating point error is and how imporant convergant is? also what is the different between pressure-far field and pressure inlet and outflow-vent. do you racken i have set up the model correctly?
Old   May 19, 2004, 09:04
Default Re: Help on project!
Andy
try www.eng-tips.com
They've got a cfd forum as well as a few cfd specialists who hang out in the engine forum that can probably help.
Andy
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
Extend Project Release 1.6-ext hjasak OpenFOAM Announcements from Other Sources 33 July 14, 2011 19:54
PhD Project: Computational Modelling of Tidal Turbines grtabor OpenFOAM 1 May 31, 2011 11:28
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 10:33
CFD project idea John Cleveland Main CFD Forum 4 March 8, 2005 13:55
