Complex Error Function
Old   April 11, 2004, 16:34
Default Complex Error Function
Wen Long
Hi, friends:
I got a question on trying to solve unsteady diffusion problem using Green's function method, where I found that the Green's function in my case involves complex error function,
such as: erf(a+b i),
do you know how complex error function can be calculated?
thanks,
Wen
Old   April 11, 2004, 16:38
Default Re: Complex Error Function
noName
A complex error function is simply an incomplete gamma function. See the mathematica website:
http://mathworld.wolfram.com/Erf.html
http://mathworld.wolfram.com/Incompl...aFunction.html
I think they should be easy to calculate by recurrence relations, but I have never done this before.
Complex Fields suniljain OpenFOAM 1 September 12, 2019 09:09
[ICEM] complex 2D meshing on ICEM kassab ANSYS Meshing & Geometry 26 April 14, 2014 22:02
Complex .stl data for volume meshing in ICEM CFD Nils_H ANSYS Meshing & Geometry 5 September 2, 2011 09:39
Complex fields and equations JScott OpenFOAM Running, Solving & CFD 0 September 22, 2010 16:59
how to locate particle under a complex gridding harry Main CFD Forum 0 August 17, 2005 10:27
